- Mar 25, 2013
- 4,645
I just bought some mini 3mm Molex connectors. They came with no assembly instructions and believe it or not they do not exist on the company's website.
I cannot figure out how to insert the pins in the plastic holders. The Molex connectors I have used in the past had round pins so the orientation didn't matter. These pins are square, hence there are 4 ways to insert them. The male pins go in fine and lock. The female pins will not lock into the housing. Yes I am aware that they have small retaining barbs and I have made sure these are opened up. I am not sure if these are defective, a bad design or I am using them wrong. Have you used these? What is the correct orientation of the pin? Is this documented somewhere?
Thanks
Robert
Thanks
Robert
