- Nov 28, 2016
- 2,375
I've just acquired an old Arter carbide grinder... this is the grinder that Terry (@tjb ) had advertised here 'free to good home'.
I am planning to overhaul this grinder, or make an effort to, anyway...
It seems to be in fair condition, no major damage, there are a couple of parts that I have determined to be missing.
The spindle motor is mounted to the lower back of the stand. It is connected to a double intermediate pulley with a belt... the intermediate pulley is then connected via a belt to the spindle. The spindle head is mounted on a spring loaded arm, so it will swing a couple of inches vertically. I haven't figured out why it was designed this way yet, but there has to be a reason...
The machine tag is stamped '440v'... so I'm assuming the spindle motor is configured for 440... there is also a small coolant tank with a 110v pump.
The tank/ pump...
There is a transformer wired to a 110v outlet, presumably to plug the pump into...
Since I don't have 440v service, I will have to do some 'reconfiguring'...
I've determined how the tables and table tilt assembly mount in place... each table is supported by two flat plates between the table and table frame... held together by two strong coil springs.
It's an interesting design... but one of the support plates is missing. I'll have to make one... it should be pretty easy.
There are two handles on the front of the grinder...
...the lower one is a Furnas reversing switch. The upper handle... I have no idea... it just swivels, and isn't connected to anything inside...
I haven't been able to find any information at all about this machine... Arter is still in business, and their website mentions this grinder...
I may call them next week and just see if they have anything at all that they could send me... even pictures would be helpful.
-Bear
The tank/ pump...
-Bear
