- Jun 12, 2014
- 4,826
I have a hydraulic SFJ Fischer Swiss Live Center with a pressure Gauge I picked up years ago, but they rarely come up at a reasonable price. Interestingly the Phase II has a pressure compensating spring for thermal expansion, at $70 it is inexpensive and Phase II can make decent machine accessories. I would think that if someone like Royal made a spring live center, it would work as advertised, the one I looked up had an accuracy of +/-0.0001" for $339.
Phase II Live Center Description:
The rotating spindle is extended right through the tapered shank.
Two specially designed adjustable needle-roller bearings carry all radial loads.
A heavy duty ball thrust bearing takes all axial thrust.
Thermal expansion and shock loads are absorbed by a special compensator spring.
Complete protection of bearings from the ingress of coolant dirt or swarf is provided by the built-in oil seal which also prevents loss of lubricant.
CONCENTRIC 17103 3MT Standard 60 Degree Angle Live Center
BenefitsLow profile design gives less overhang, greater load capacity and increased rigidity.Smaller turning radius allows higher RPM's lower bearing speeds.Needle bearings distribute stress for up to 6,800 lbs. radial load capacity, extend life 2 to 3 times that of conventional live centers and...
www.travers.com
PHASE II Precision Heavy Duty Live Centers
Allow For Higher Turning Speeds With Less HeatAchieve Precision Results Without The Need For Separate LubricationReduce Thermal Friction when Turning with Phase II Precision Heavy Duty Live Centers. These heavy-duty live centers are well-adapted to hold a workpiece in a lathe or other machine...
www.travers.com
