- Mar 30, 2014
- 115
I have been using this stuff for years. I was first turned onto this stuff where I work (john deere service tech). We swear by it there. We use it to lube about anything that needs/can use a spray lube.
I use it on my jeeps, its a great assembly lube for oil seals and rubber parts (especially o-rings) I spray it on bare metal parts I do not want to rust. I have a a axle torn down right now in my shop and I sprayed down the spindles like 2-3 years ago and its still there, still slick and still no rust. My shop is not temp or humidity controlled.
When I first bought my smithy, there was a few spots on it where they previous owner never really wiped it down with oil and started rusing. I sprayed on the fluid film and worked it in with some fine scotch brite pads and it cleaned it right off. I use a rag sprayed down with it to clean and wipe down my machine after every use. Its in the same shop that is not temp or humidity controlled. I have yet to have any rust.
I goofed up one time and left some cleaned and bare transmission gears settin on the workbench and came back a couple days later to find a light dusting of rust because of the humidy. I quickly sprayed them down with this stuff. It helped clean the rust off and stopped any more from forming.
I reccomend if anyone has the chance, pick up a can and give it a try. Also interested to see if anyone else uses it. Google it and you will find all kinds of info on it.
http://www.fluid-film.com/
