- Aug 5, 2015
- 237
Another QUESTION about Mini Splits in Austin Texas area.
I have a two car attached garage with an insulated door, one wall shared with the house, and two limestone veneer outside walls that are not insulated. The garage has two standard sized double paned windows. The ceiling above is the shared attic space with the house, and has blown in insulation over the garage ceiling.
My AC contractor has proposed to install a Mitsubishi 12,000 btu combo ac and heat pump. He measured the space and said the 12k unit would do and that it is not a good practice to oversize.
My question is: Should I bump that up to the 14/15k unit size?
