Thanks for all the answers guys. I didn't even think about printing out a division wheel. When I initially posted this question, my thoughts were to use the indexing plates that came with my rotary table, of which I have several, but it seems that I would end up with the last tooth being off by a very little, but it seemed very complicated to me.:nuts:
I use this printable "wheel divider":
http://www.cgtk.co.uk/metalwork/divider
Just enter 113 elements and print it out, glue it to something and attach to your spindle or ??? Modify the print size to make it fit your diameter.
I like this solution the best, a simple solution for a simple mind, like me.
Can you not use a set up for 226 divisions and skip every other hole?
I don't see how that would make it easier....why not just use the 113 holes and be done with it? I guess the math might be a little easier, but with the printable wheel, who cares.
This was gonna be an exercise with my divider plates, but quite frankly, I'd rather do it the easiest way possible. To that end, I already have a 113 tooth gear that I can use to index off of for this particular gear, but I also want to do a few others. There's a 127 tooth gear that I want to make and also a 71 tooth gear that I don't have patterns to work off of.
The gears are metric 1.5 module with a 20 degree pressure angle. I just ordered the cutter set. This will be my first gear hobbing experience, this should be interesting. Figuring out the Blank size OD is not a big deal using the formulas in the Machinerys Handbook.
Thanks again guys.
Marcel
