- Feb 28, 2019
- 507
I'm stumped. There must be some tricks to that make it easy (or easier) to get an accurate inside diameter of a shallow bore.
I've got a part that I want to turn a shallow 1" dia. bore into. The depth is only about .050 and it's too shallow for the telescoping bore measuring tools.
When I try to use the pointy tips of calipers I get readings that vary +/- .003 because it's hard to find the true diameter with the caliper tips.
Is there some special tool or a clever trick for getting an accurate measurement in this case?
I did try a short piece of 1" drill rod and was able to use little bits of plastic shim to determine that I over shot it to 1.003, but there has to be a better way to do this while turning it.
