- Jul 20, 2012
- 1,238
Re: Any shtips on soldering a new bandsaw blade?
So you put the silver solder between the parts and not heat it up and let it wick in like soldering copper pipes?
A friend gave me mine, but i see it is listed on ebay. The thinner the better and a very small amount. You first flux both sides of the angles ground on the blades, then insert the silver solder between the blade ground angle. Then heat up tell it melts, let it cool then heat back up tell it is blue, to draw it back and then grind tell the thickness it around the thickness of a blade or a little larger.
