- Nov 20, 2014
- 758
I know this is not too technical but I am getting ready to install my x power feed for my bridgeport. I took the nut off, the handle off and slid the locking collar off the shaft. BUT the front woodruff key/half moon keyway is stuck, no movement, I tried to grab it with a vice grip and tap the vice grip, no go. The one closest to the table will tip front to back when I tap it so I think it will free up without an issue. Do you think heat will be my friend?? Heat it and then pull or tap it?? thanks for your suggestions. My last effort may be to grind a slot down the center and start picking it out.
