- Nov 26, 2018
- 286
It would work, though you may put more effort in to making the tool than threading three times and doing the trig to offset the single point tool.
Welcome to the forum.Just curious what the perspective on making a custom 3 point HSS cutter head and running it at .8 mm? Sorry if this falls in the stupid questions category. I will forgive anyone that mocks this inquiry.
Another way would be to use the compound and do the math. The half nuts would be engaged , the compound and cross feed would be zeroed and the first lead cut. Then the compound returned to zero and would advanced by .0315"(.8mm) if the compound was set parallel to the spindle axis or .0640" (.0315/sin(29.5º) if the compound is set to 29.5º. The compound dial would be rezeroed and the the cross feed brought to touch the major diameter and rezeroed and the second lead cut. The procedure would be repeated for the third lead.
You are correct. The gearing should be set up to advance the carriage 2.4mm/rev. To cut the second pass, you have to either turn the work 120º, leaving everything else as is, or move the threading tool .8mm toward or away from the headstock while leaving everything else as is. The third pass would be set up by moving another .8mm.Thanks for the info. I have cut multi-lead threads before, but all english. For example, one I routinely cut is a quad 7tpi, finished thread is 28tpi... so thread offset and depth is based off the pitch of a 28tpi thread (.0357 which I round up to .036).
When it comes to metric, maybe I am confused... but I was approaching it as finished thread pitch of .8 would require three leads cut at 2.4, which would provide the space between leads to stack the threads..
Mr. Pete does a good job of explaining this in his video linked above (there is a small error about 16:30 in the second part where he is explaining why the 29.5º compound angle is used; the tool cuts the mostly on the right flank of the thread but it also shaves the left flank due to the .5º offset from 30º).
The math isn't really that bad. You have a right triangle with a 29.5º angle. The compound advances along the hypotenuse but the adjustment needed is in the z direction of the short side of the triangle (opposite the 29.5º angle). The z axis travel divided by the compound travel is equal to the sine of 29.5º. You have to remember to rezero the compound and the cross slide. You can calculate the cross slide adjustment as well since the cross slide travel divided by the compound travel equals the cosine of 29.5º. It saves you the bother of touching off the tool again to zero the cross slide.I actually just watched that video independently, and the 1 thing that confused me (until I researched it) is how to figure out cut depth. He spends about 20 minutes showing off examples, and 30 seconds stating the thread depth The idea is that the depth is based on PITCH, not LEAD, which makes sense to me.
A double-start 5/8-12 (PITCH) has the same cut depth as a single-start 5/8-12, except you simply move the carriage toward the headstock at 2x the speed. So other than the gearbox setting, a double-start thread is the same as cutting a single-start thread in every other dimension.
I DID like the idea of using the compound to advance the cutter. It is much easier than my original thought (which was backing up/advancing a 29.5 degree compound by a specific amount, then re-touching off with the cross slide). It seems my way would still let you do the 29.5 degree compound, but the math seems onerous.
