- May 16, 2016
- 1,698
You don't need excessive blade tension to cut metal well. Properly set up, it doesn't take any extra tension at all.
I find that the blade jumps off the pullys if not very tight.
I find that the blade jumps off the pulleys if not very tight.
What I mean is that blade tension is solely related to blade width and thickness. A 3/4" .030 blade for wood or the same dimension blade bimetal metal cutting blade need the same tension. There is no difference at all. If you are making the metal blade much tighter, then either your wood blades aren't tight enough or you are overstressing the metal blades leading to breakage.
I've been using a metal/wood 18" bandsaw for 30+ years using blades from as little as 1/8" to as much as 1.5" on the same saw. I haven't
broken a blade in probably 20 years. I've never had a blade 'jump off the pulleys'.
How do I set the tension? sound. I adjust until I hear resonance in the blade and then tighten a little bit. If the pitch changes suddenly, it is too tight, so I back off a bit. The scale on my machine is way off! When I first got my machine, I broke blades because I went with the scale.
I get that the blade tightness is related to the blade thickness and width, and while I have never broken a blade, I think that my blade tension is higher than it should need to be, basically I have to tighten my blades as tight as I can get them or they jump off the pulleys. My machine has metal wheels without rubber or urethane tyres. There is no crowning on the wheels, the blade runs with the back edge of the blade against a small shoulder or flange on the wheel. Sometimes it will run for hours then all of a sudden it will just jump off the wheels, This happens more often when cutting wood than with steel.
Really good points. One thing I would check is that your wheel faces (that the blade runs on) is exactly perpendicular to the rotation. If there is a small wobble, or if the wheels were faced wrong, there would be a tendency to have the blade jump.
It will happen more in wood becasue the metal works as a secondary guide if there's a wobble, but the wood won't.
Those tilt tracking are not for bearing wear. They are for getting the blade to ride on the crown of the wheel if they don't. Bearing wear is something that should be addressed wen it happens. Like any other machine, a worn bearing is not working efficiently. 2 things can happen, you can have a heat build up and ruin the shaft, or you can have a catastrophic failure where the race is ruined and the wheel blows off (rare). A well adjusted saw is one that has the blade riding on the crown of the wheel.I don't cut wood with my 4x6 so I wouldn't know. But usually when the saw was getting marginal it would jump whenever the blade would catch. Either on a kink in the blade or where there was some missing teeth. Cranking down the blade tension helped a little but it usually sped the deterioration of the bearings or bushings that we're going out. Some metal cutting saw's have a takeup wheel tracking tilt adjustment to help compensate for bearing wear. Usually you can look at the wheels under tension and see if they are tilting.
