- Feb 17, 2013
- 4,407
I bought some interlocking gray 2' square mats from someplace (Home Depot?) years ago. I do like them - easy to put together and make pathways between the tables and equipment, easy to custom cut, easy to sweep, etc.
So, last year I decided to try extending the covered area. Bought 6 packages of similar looking mats from Harbor Fraud. BIG MISTAKE. First off, the HF mats have "continuous" edges ... the originals have an oddly shaped interlock point in the middle of the 2 foot span, so you can join the mats halfway across. No real problem. It was fixable with just a bit of creative knife work. And the different pattern (fine-pitch ripples vs "diamond plate") was not really an issue.
But then the )&$$&%##@!!!@#@#$$ showed up. The HF mats are about 1/2" shorter than the originals!!! They just refuse to play nicely with the others - buckling, gaposis, etc. I ended up returning 5 of the packages.
Guess I'll have to go back to HD - WITH a sample of the original border, just to make sure things fit together. Bother!
