- Feb 1, 2015
- 9,649
My motor has an external press on fan and I will go with that initially. There is concern about insufficient cooling at low rpm for motors with built in fans and one solution is to use an external high volume computer fan for cooling.
Banggood has something like 250 different motor controller on their site but none that I saw that meet the requirements of 120 v.a.c. input and 15 amps out. It woulden't ake much to modify one though. You would need to add the full wave bridge, the filter capacitor, and a suitable MOSFET transistor to be able to use with a higher hp motor.
From what I have read, the undesirable soft start feature of the OEM treadmill controllers can be defeated by simply snipping one resistor.
