- Jun 12, 2014
- 4,816
I do not get it either, unless your chuck mount was out. I would check that when you have the test bar in and rotate the spindle that the reading TIR should be nil, check the spindle mount that it is also running true. End of the day is that it cuts true over at least 6-8" unsupported with larger diameter stock. I am not sure about using a test indicator for this application as any change in height when sweeping the bar would have a large impact on the reading.
Getting a good precision level sure helps with setting everything up, lots of crap out there and anything decent is 2-3X prices from several years ago. This one popped up when I did a search, VIS are quite good for the price. Know nothing about this listing service.
Precision Machinist Level - $100 In Baxter TN - LSN
VIS 12" Precision/Machinist Level-0.0005"/10"-Made in Poland
www.lsn.com
