- Mar 8, 2015
- 311
I saw this on YouTube and decided to give it a try. It mounts to compound after you take off qctp. The big hole isn't supposed to be there . It was already in the scrap of metal I used. Note the slit. It allows the block to close down on the the tool when you tighten down the the 3/8 16 bolt which secures the whole thing in place. There is no adjustment for blade height, i had to scribe a line from a headstock center befor I started milling. I used that line to locate the top of the tool before I milled the slot. Mine came out a few thousandths high which was my plan since it would be easy to mill a little bit off the bottom. Worked fine without any milling required. Works good and eliminates a lot of the flex which can cause trouble when you are parting.
At any rate, I am very pleased with how it works.
