- Nov 28, 2016
- 2,373
I finished cleaning the apron and cross slide yesterday, this morning I painted them. While they are drying, I have turned my attention back to getting the Buffalo Forge drill press running. Figuring out the best way to route the wiring from the motor (on the bottom right of the press) to the switch (on the top left) and keep it away from all the various pulleys, belts, gears, and handles wasn't easy.
I finally came up with a plan. I routed the wire out of the motor up the rear frame brace (through conduit)...
...all the way to the top, then over the top gearing...
...then down, straight into the drum switch...
The power wire comes back up from the drum switch to the ceiling, and across to the breaker panel.
I mounted the drum switch upside down for 2 reasons... first, it was easier to route both wires, I didn't have to come out the bottom of the switch, then have to make a 180 degree bend to go back up. Second, with the switch handle on the bottom, I can reach it while working from a chair... the table is pretty low and fat guys like me don't like standing on our heads for very long...
I wired it all up and fired it up... it runs great! I do have a noise in the upper gears... it sounds like a gear is scrubbing one of the covers. Hopefully it just needs an adjustment.
Back to the Hendey tomorrow...
-Bear
-Bear
