- Oct 21, 2014
- 2,156
Ok, Have been working my old Taiwan made 10x24 lathe over. All new bearings in the head things cleaned up and the spindle set up taking all the slack out with the indicator etc. Now trying to get it back in alignment with the ways. since I do not have a known good test bar, in fact I know it is not as can see bend in it on a sheet of glass.
Have been trying a method I saw on here called. Rollie's Dad's Method of Lathe Alignment
But having problems with the alignment. Set up on center line with wide flat tip so movement off ceter just a little does not affect it.
close to the chuck reads 0 and 3, and other end reads plus 25, and minus 32, (told you the bar was not straight)
thus 0+3 = 3 divided by 2 =1.5
25 +32 = 57 divided by 2 =26.5
1.5 - 26.5 =25 25 thou out on the outer end.
watching the gauge on the on the end of the shaft Moved it 12.5 thou or 1/2 of the amount.
problem was once went back and did all the measurements and calculations again
it was still a diff of 25 thou on the outer end.
Am I doing something wrong,
any help please
any help please
