- Dec 24, 2020
- 1,069
My apologies in advance for adding yet another drum switch question to the forum. This has been a heck of a rough week and I am just mentally fried. I've wired a drum switch a couple of times in the past, but I'm drawing a blank this time.
This is a Furnas R44 switch on a lathe. The motor is an Atlas Super Power 1hp 110/220 with no diagram. The junction box on the side normally has the diagram on the cover, but that was missing when I bought the lathe. It was wired for 110V and I'm not even sure they did it properly as it was struggling in the highest/fastest gear so that a moderate load would trip the breaker. I decided it was time to change it over to 220V.
I ohm'd out the leads and 3/6 and 4/5 are the main windings and 1/2 are the starter winding. I powered the motor directly in both forward and reverse with no issues. I also did some turning with it in the highest gear with a negative rake insert and it easily threw some big chips, so I'm pretty confident the motor is okay...it was a night and day difference in how much power it had.
I'm just down to sorting out the wiring for the drum switch. I've made a drawing for the switch and how I powered the motor directly for forward and reverse successfully. Any advice in how to wire the switch would really be helpful!
