- Mar 25, 2013
- 4,624
Do you have a gear puller that will fit over it?(or make one) Put some load on it with the puller and tap the sides of the pulley without denting the aluminum. If the motor is shot, cut off the shaft and tap out the remainder from the pulley. Does anyone know if that motor is original? The motor on mine is labeled Clausing.
Robert
Robert
