- Dec 18, 2013
- 2,363
are ballscrews recommended for manual machining? I've read in a bunch of places that they're generally a bad idea due to their extremely low friction relative to leadscrews. If you have a DRO then any backlash in a leadscrew should be a non-issue, right?
A zero backlash preloaded ball screw nut has plenty of grip on a ball screw and short of linear ways the table isn't going anywhere on its own with either type of screw. Remove the screws and nuts altogether and adjust the table gibs to a slight drag setting, it takes some effort to move the table in either x or y, the screws just make it seem like its loose and easy. The only axis I would be concerned with is Z where you have the weight of the head pushing down and motor vibration working against you. I would want that axis locked either mechanically or via stepper/servo motor with either type of screw. A ball screw is going to be more accurate, easier on power feeds, and last longer than a brass nut.
