    Dismiss Notice
Angle of HSS turning tool to work
Discussion in 'A BEGINNER'S FORUM (Learn How To Machine Here!)' started by Jmanb13, May 3, 2017.
  1. Jmanb13
    Jmanb13 United States Active Member Active Member
    58
    18
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
    As I've been reading more and more about grinding HSS turning tools.
    One of the most complete ones i've seen is the following.
    http://www.steves-workshop.co.uk/tips/toolgrinding/toolgrinding.htm
    Specifically this picture.
    [​IMG]
    I see information around all the different relief and rake angles for different materials, but not the side cut or end cut angles.
    Does the side and end cut angle matter and is there a recommended angle?
    In regards to all of these angles, do these angles all assume the unground portion of the tool is 90 degrees to the work?
    jlsmithseven and Ulma Doctor like this.
  2. Ulma Doctor
    Ulma Doctor Infinitely Curious Active Member
    3,050
    113
    Ethereal Plane
    City:
    Tracy
    State:
    California
    -Return to Top-
    side and end angles can be anywhere from 5* to 15* in most cases
    the back rake shown in the drawing is for when using lantern type toolpost with a toolholder
    a lot of the armstrong type holders have a 7* angle built into the holder, you'll need a bit more end relief in that case
    a QCTP won't need the back rake and can be more acute on the end relief.
    side relief, do as you please anywhere 5* to 20*.
    5* for tough materials, up to 20* for easier to turn materials
    Rustrp, Jmanb13, mikey and 2 others like this.
  3. mikey
    mikey Active User H-M Supporter-Premium
    2,575
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    The side cut and end cut angles in the illustration are more commonly referred to as the side cutting edge angle and end cutting edge angles, just to clarify the terminology in case you need to look it up.
    Technically, they do matter. In the tool illustrated above, that is the profile for a roughing tool intended to be used with the shank perpendicular to the work. Note that the end cutting edge angle is less than 90 degrees relative to the side edge and this allows the nose of the tool to access corners so you can use that tool shape to both rough and face. Of course, you will need to alter the tool angle to face with it but the same tool will both turn and face because of that more acute angle.
    The side and end cutting edge angles will vary with the purpose of the tool. Roughing tools will have a less acute side cutting edge angle and facing and finishing tools will have a more acute side cutting edge angle. Traditionally shaped tools, as shown below, were used with the shank perpendicular to the work and these different angles were intended to allow the tool to work better for different operations.
    [​IMG]
    When the tool is positioned with the shank perpendicular to the work, the side cutting edge angle is equal to the Lead Angle (LA) and the LA has an impact on cutting forces and finishes. The less acute the LA, the lower the cutting forces are so a roughing tool has a less acute side cutting edge angle. Conversely, a more acute LA will produce a better finish so the finishing tools have a more acute side cutting edge angle.
    Of course, most of us use a QCTP nowadays so these shape constraints are not as rigid as they used to be because we can turn the tool to any angle we want. In this case, all we need to assure is that the end cutting edge angle is less than 90 degrees so we can cut shoulders.
    Insofar as the relief and rake angles are concerned, that is a much deeper discussion but yes, they do matter ... a lot.
  4. Jmanb13
    58
    18
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
    I do have a QCTP and that is what really prompted me to ask the question, because I can have the HSS tool approach the work at any angle I want.
    I have the southbend how to run a lathe book which lists the tool shapes you mentioned in your post but of course they had a lantern tool post in mind. Do you know of any sites/books/videos that discuss grinding bit shapes specifically for use in a QCTP?
  5. Doubleeboy
    Doubleeboy Active User Active Member
    279
    63
    City:
    Eugene
    State:
    Oregon
    -Return to Top-
    Jmanb13, Mikey is the guy when it comes to sharpening HSS, he has a long thread on it here on HM. Might look up his past posts or do a search. Very nice tutorial.
    mikey likes this.
  6. mikey
    2,575
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    To be honest, I haven't seen a really good book on this subject but there are tons of videos on YouTube. Most of the videos discuss tools suitable for use in a QCTP. The thing that sets a more modern design apart from tools intended for a lantern tool post are the back rake angles - they are either smaller or non-existent in tools made for a lantern tool post because the tool post holds the bit at an upward angle already so you don't need to grind the angle into the tool.
    Here is a thread I posted on grinding these tools. At the end of the original post are some links that may provide more info you might find useful. http://www.hobby-machinist.com/threads/how-to-grind-a-hss-turning-tool.52581/
    When you use a HSS tool in a QCTP, the angle of the tool can be whatever you want. The questions I think you have are "what angle should you use, when should you use it and why?" I suspect every one of us has asked ourselves these questions at some point so you're not alone. The answers aren't that complicated so I'll try to explain them.
    If you use an inserted tip carbide tool then the tool shank is intended to be held perpendicular to the work. All the clearance angles are designed into the tip geometry of the tool and insert and all you need to do is set the tip of the tool to center height, get it perpendicular and you're set. Brazed carbide tools are, in general, used the same way. HSS tools are shaped and have varying geometries so we need to understand things a bit better to get the best use out of the tool.
    A HSS turning tool cuts most efficiently when the lead angle of the tool is appropriate for the operation; to really understand this tool angle thing, you have to understand what lead angle is and what it does.
    [​IMG]
    The lead angle (LA) of a turning tool is determined by the side cutting edge angle of the tool and the way the tool is angled to the work. When the tool shank is perpendicular to the work then the LA is defined by the side cutting edge angle, as in the third example above. We can change this LA by turning our QCTP. So, what is the big deal about LA and why does it matter?
    Basically, the LA of the tool alters cutting forces and affects finishes. The lower the LA, the lower the cutting forces are and the rougher the finish is; the greater the LA, the higher the cutting forces are and the better the finish is. This cutting force thing has a lot to do with the amount of surface area that is in contact with the work. When the LA is high, more of the side cutting edge is in contact with the work; when the LA is lower, less cutting edge is in contact. If you use a high LA and then try to take a heavy cut, cutting forces increase and you get chatter; backing off on the depth of cut reduces cutting loads, the chatter goes away and your finish improves. Conversely, using a lower LA brings less surface area into contact so you can take deeper cuts without chattering, albeit with a less refined finish. So, what does this have to do with tool angles and tool shapes?
    The angle of the tool in use is determined by the operation. If you are roughing, angle the tool so that the LA is lower (like the middle pic above). If you are finishing, increase the LA (like the pic on the right, above). When the LA is low, you can take a heavier cut; when the LA is high, you have to take a lighter cut. The lower LA is used for roughing and the higher LA is used for finishing. For facing, the LA is negative such that you are cutting with the forward part of the side cutting edge, up near the tip. Facing depths of cut can be light or heavy, depending on your needs, because only a small area is in contact and the potential for chatter is lower.
    Tool shapes are not as critical when we use a QCTP but they do have an influence on how much or little you angle your tool. You will find that the LA you end up using for a given operation will put the side cutting edge at an angle very close to what the older shapes did when their shanks were perpendicular to the work.
    Bear in mind that we're just talking about tool shapes and lead angles here. Cutting forces are definitely influenced by these things but the relief and rake angles have a much greater impact. That is a discussion for another time.
  7. Jmanb13
    58
    18
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
    Some great info there! So it seems with a QCTP you could conceivably grind a single tool and simply alter the lead angle do roughing and finishing cuts on the same tool.
    I might need to try regrinding some of my bits to see what I can do. The existing ones I have been using were old used bits from ebay that I simply touched up and honed. They have worked well enough, but my surface finish leaves much to be desired.
    mikey likes this.
  8. mikey
    2,575
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    Yes, a general purpose tool shape will work for most tasks - just change the lead angle. However, do not make the mistake of thinking that shape is all there is. Each material you work with has required relief and rake angles and these are far more important than just the shape of the tool.
    What kind of lathe are you using? This also has an impact on how the tool is ground. Smaller, less rigid lathes will require larger rake and relief angles to lower cutting forces; larger lathes can get away with more standard angles. You will hear that tool angles are not important and close enough is good enough. The smaller the lathe, the less true this statement is.
    DHarris likes this.
  9. Jmanb13
    58
    18
    City:
    Norman
    State:
    Oklahoma
    -Return to Top-
    1946 15" Leblond Regal Trainer. 500RPM in top gear, a little more if I overdrive the motor with my VFD.
    jlsmithseven likes this.
  10. Rockytime
    Rockytime United States Active User H-M Supporter-Premium
    100
    43
    City:
    Arvada
    State:
    Colorado
    -Return to Top-
    From a watchmaker's lathe, to a Sherline, to a 7" MaxiMat to a 12" lathe, I have always left the top of the cutter un-ground. Perhaps I suffer from some inefficiency, I don't know. I guess it is because the things I cut brass, aluminum, 12L14 and some cast iron. These materials are so easy to turn I have to problem. Perhaps with more difficult steels I would have a problem. Another reason is it is one less face to grind. Another reason to use inserts, even on my Sherline.
  11. mikey
    2,575
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    Okay, big lathe, low speed. You can grind a general tool shape and use the rake and relief angles found in any lathe tool angle table.
  12. tomh
    tomh Active Member Active Member
    152
    43
    City:
    oxford
    State:
    Alabama
    -Return to Top-
    The youtube channel "thatlazymachinist" has some in depth videos on grinding the angles on HSS with some interesting results that are worth watching as well as "mrpete222".
    Rustrp likes this.
  13. mikey
    2,575
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    What is the maximum depth of cut you can take on your Sherline with those inserted tip tools or with a flat topped HSS tool in say, 12L14?
    I ask because I also own a Sherline lathe and I can easily take a 0.050" deep cut in 12L14 with a good HSS tool. On my 11" lathe, I can easily take a 0.20" deep cut before I have to step the gearing down; and then I can go deeper. Tool angles enable a lathe to work much more efficiently than most of us realize.
    Edit: @Rockytime , I re-read my post and it sounds like I'm being confrontational. My apologies as that was not my intent. What I really meant was that when we use side and back rake to full advantage it greatly reduces cutting forces and cutting temperatures so as to make a smaller lathe more efficient. I am not challenging your preference not to use them but I am suggesting that perhaps it might improve your experience. Again, my apologies - I sounded like a real dick and I didn't mean to come off like that.
    Currahee26 and Rustrp like this.
  14. wawoodman
    wawoodman himself, himself H-M Supporter-Premium
    645
    113
    Seattle, WA
    City:
    Seattle
    State:
    Washington
    -Return to Top-
    I've watched most of them, and I think I like This Old Tony.
    Jmanb13, MonkMan and jlsmithseven like this.
  15. jlsmithseven
    jlsmithseven United States Active Member Active Member
    152
    43
    City:
    Ephrata
    State:
    Pennsylvania
    -Return to Top-
    That's a pretty informative video. Great for beginners!
  16. ddickey
    ddickey United States H-M Supporter - Premium Content H-M Supporter-Premium
    443
    63
    City:
    Red Wing
    State:
    Minnesota
    -Return to Top-
    So this is why a solid tool post won't work if you use HSS ground tool bits.?
    Currahee26 likes this.
  17. mikey
    2,575
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    If you only use inserted carbide tooling then the tool post can be fixed. If you plan to grind HSS tools with their profiles fixed, meaning you will grind a tool for roughing, facing and finishing for each material class then sure, you can fix the tool post. However, if you plan to use general purpose tools then you need the ability to alter their lead angles for different operations and that means the tool post cannot be fixed.
  18. ddickey
    443
    63
    City:
    Red Wing
    State:
    Minnesota
    -Return to Top-
    boo.
    mikey likes this.
  19. mikey
    2,575
    113
    City:
    Honolulu
    State:
    Hawaii
    -Return to Top-
    Yeah, I know.
  20. Rockytime
    100
    43
    City:
    Arvada
    State:
    Colorado
    -Return to Top-
    Hi Mikey, Absolutely no offense taken. I do understand that proper grinds are necessary when doing production work. Time saved is more profit in the work. I, however, do mostly small projects such as making clock repair parts. Most often I am cutting brass and aluminum and occasionally 12L14, the 12L14 usually used for making small screw. At present I am building the PM Research small mill engine with aluminum castings with only a 1/2" bore. Very small engine. That is why I don't bother grinding the top relief.
    Ken from ontario and mikey like this.
  21. hlj3
    hlj3 United States Swarf Registered Member
    2
    1
    City:
    Everett
    State:
    Washington
    -Return to Top-
    I really like this tool bit video. Good technique.
    H L
    Ken from ontario likes this.
  22. benmychree
    benmychree United States John York H-M Supporter-Premium
    489
    83
    City:
    Saint Helena
    State:
    California
    -Return to Top-
    The main thing about lead angle is that if you are roughing with zero lead angle, the tool tends to creep in, and likely cut undersize if you are roughing close to size; the lead angle puts pressure outwards on the tool, so that the tendency to creep in is eliminated.
  23. Ken from ontario
    Ken from ontario Canada Active Member Active Member
    293
    63
    City:
    Peterborough
    State:
    Ontario
    -Return to Top-
    I have a question about back rake angle, what is a back rake angle?
    why it 's not needed with a QCTP?
    if it is not often ground in a turning tool then why do we even mention it?
    Please remember I have seen pictures of back rake angle (when I googled it), it sounds like it is used for woodturning when a sharper angle is needed but the point of the question is, nowadays most people who grind their HSS cutting tools for turning and facing,do not incorporate a back rake angle in their cut but it's always mentioned .
  24. Jimsehr
    Jimsehr United States Active User Active Member
    139
    43
    City:
    SOULSBYVILLE near sonora
    State:
    California
    -Return to Top-
    Remember the quality of HSS tools is much better then it was when most of the old machining books were printed. I have been machining for over 60 years and can remember some of the poor tools of the day. In those days some of the angles made more sense then then they do today. I have even used dowel pins to make cutting tools in a pinch for cutting alum and other soft materials. Most tools today use top rake but they call it chip relief. I hand grind all my tools in my home shop even the radius tools used to cut the balls in my Avatar. I don't think many machinist of today
    grind tools old school. There is nothing wrong with that but in the old days you could not buy ready made tools like you can today.
    Jimsehr
  25. GoceKU
    GoceKU Macedonia Active Member Active Member
    342
    63
    City:
    Kumanovo
    State:
    Outside US / Canada
    -Return to Top-
    "In those days some of the angles made more sense then then they do today", This is funny, recently i've bought lot of HSS tools and first thing i thought those angles make no sense, how ever ground them was more concern about the chip braker then the cutting angle. DSC_0020.JPG
  26. Jimsehr
    139
    43
    City:
    State:
    California
    -Return to Top-
    I started machining over 60 years ago and I thought some of the books on grinding tools were out dated then. And if I took as much time grinding a tool as the guy in the video did I would have been fired in no time. I worked in a production shop where time is money. Also guys in home shops are not making 1000 pcs at a time so if the cutting edge won't last for a lone time it is no big deal. If the tool works for what the home shop needs cut it is fine. I have tried some of the new cheap Chinese insert sets and they work great.
    Jimsehr
  27. GoceKU
    342
    63
    City:
    Kumanovo
    State:
    Outside US / Canada
    -Return to Top-
    Cheap Chinese carbide insert work great for a short time, they seem to chip, break easy, the high quality german, dark grey, are my favorite, cut great and take lots of abuse and don't chip just cut and cut.
  28. benmychree
    489
    83
    City:
    Saint Helena
    State:
    California
    -Return to Top-
    Back rake makes HSS tools cut more freely, rolling the chip back away from the tip of the tool; the Armstrong and similar too holders hold the tool on a 15 deg. back rake, but that much is not necessary; I think that the idea was that in sharpening the top of the tool that eventually it ends up more nearly parallel with the tool holder, as more is ground off the nose of the tool. It gets to a point where you sharpen the cutting flank, the front and top of the tool, you keep up the same routine, and the tool can remain the same shape without cutting down its thickness behind the top rake grind, reducing its strength or making it necessary to cut the end off and start over with a whole new grind as you would with a quick change (parallel) tool holder. Bottom line, you get longer tool life with the 15 deg. holders.
    I do not agree that we had inferior HSS tools 50 years ago; the same premium brands and types are still here and available, although some shops may not have used them back then, as obviously they are more expensive.
  29. Ken from ontario
    293
    63
    City:
    Peterborough
    State:
    Ontario
    -Return to Top-
    So it sounds like it is a personal preference to grind a back rake in the tool and not necessary :confused:.
  30. benmychree
    489
    83
    City:
    Saint Helena
    State:
    California
    -Return to Top-
    Personally, I grind HSS tools for the lathe for use in QC tool holders with no back rake, just side rake, and avoid sharpening on top as much as possible. I do not much use HSS tools for most work, but instead use triangular insert positive rake tools for most work except for the roughest and interrupted cuts, for which I use negative holders and inserts until things are pretty much rounded up, then switch to positive rake; this is for my 19" Regal LeBlond; for my 9" Monarch, I use HSS tools in a QC tool holder, ground as above.
    I was "raised" in school shop with Armstrong type holders and learned to grind them mostly using the full 15 deg. back rake, only with ground in chip breakers, ground on the corner of the wheel; these curled the chips and made them less dangerous to the operator than a simple top rake which had to have sufficient and appropriate feed to accomplish the same effect, they were simpler for the learner to control chips, but are easier to damage with their more acute cutting edge. When I got the old Monarch I thought I'd just use to tool holders that came with it; I'd forgotten what a pain they are to use! I quickly bought a small starter set of QC holders.
    What I think I meant was that tools with back rake cut more freely, but with QC tool holders that hold them parallel, you have to cut way into the tool bit back from the cutting point and with further sharpening, the bit is nearly ground half way through its height, weakening it, and ultimately making necessary cutting to tool off and starting the grind all over again.
Share This Page
