- Dec 29, 2012
- 394
After experimenting with a Basic Battery Capacitance Charger (BBCC) I decided to build a better one with more capabilities and options.
Some changes to basic schematic were necessary.
As you can see above, 3 capacitors of values 6, 16 and 20 uF are used in order to have a range of output power.
SW1 SW2 SW3 AMPS
ON OFF OFF 0.2
OFF ON OFF 0.5
ON ON OFF 0.7
OFF OFF ON 1
ON OFF ON 1.2
OFF ON ON 1.5
ON ON ON 2
I have a range of capacitors and high voltage rectifier bridges (removed from computer PSUs)
A dead computer PSU could provide the enclosure for the parts
Guts removed and parts fit nicely inside
Original SPST Switch changed for a DPST so when is OFF both lines (L & N) will be cut off)
I made a rectangle hole for a Voltmeter – Ammeter
This AMMETER can measure up to 300V and 10A, but needs to be powered from 7 to 30 volts DC. So a small transformer 230 to 7,5v AC from an old cell phone PSU had to be modified adding a rectifier and a filter capacitor to provide 12,3V for the AMMETER.
It fits in the box nicely
A metal panel had to be prepared for the 3 rocker switches.
A paper pattern and a few dremel cutting disks later it was ready.
A label will make the box look nicer. It is a printout on special inkjet paper with two coats of clear varnish on top.
And the box is ready
Unfortunately the VOLT-AMMETER I have measures up to 100V so I have to wait for the new one (from ebay) to have the unit fully functional.
Until then I use my multimeter to read the battery voltage.
Thanks for reading
Petros
SW1 SW2 SW3 AMPS
ON OFF OFF 0.2
OFF ON OFF 0.5
ON ON OFF 0.7
OFF OFF ON 1
ON OFF ON 1.2
OFF ON ON 1.5
ON ON ON 2
Thanks for reading
Petros
