- Dec 18, 2019
- 6,506
Well, I thought it would be machinable, up until that 1mm wide guide I put in. That would be tricky to machine. But I do think the printed piece would be pretty good. Is it 1um good - that's hard to tell. I bet it might creep after a while. It is pretty stiff relative to crushing the U. Advantage of printing this is I can be doing something else while it is printing. If I screw up, a print costs $0.89. The same piece of aluminum would be about $2. I have just enough aluminum to make one of these. If I mess it up, I do have some 1" steel I could use. A lot harder to machine though, but a lot more rigid than plastic!Curious to know if the printed version would be solid enough for permanent installation? That part looks like it'll have some challenges to make out of aluminum but not impossible.
I have the same issue with machining... then it's time to start over and try again. Or i get to almost the last step forget what i'm doing, mess up and end up starting over sometimes because my play time is interrupted and not contiguous.
I will print version D tomorrow. The version C above just kisses the tail stock ways pyramid. Other than that, the holes line up for the read head, and the U channel width is just right. Version D has a little more clearance for the ways pyramid.
I have yet to drill (and tap) the saddle for this bracket. I may use one of these prints as a drill guide. Not as good as a drill bushing, but it should do the job.
