- Dec 18, 2019
- 6,464
It seems to me that aligning a mini-lathe is a little different from bigger ones. For one, the geometry of the lathe is different. So the adjustments would be a little different.
I've found a copy of Rollie's Dad Method of Lathe Alignment. I've just done the first horizontal measurements. The test rod is ground and 20 mm in diameter. 20 mm just fits through the spindle bore. The rod is sticking out 13.25" from the chuck. The measurements for the horizontal are:
0.5" from the chuck: min 0.0000", max 0.0018", average 0.0009"
9.75" from chuck : min 0.0008", max 0.0038", average 0.0015"
So the horizontal misalignment is 0.0006" if I've done this correctly. However, I'm not sure of the arithmetic sign. Is it negative in my case?
Next post I'll have the vertical measurement.
From RDM: 9. The difference between the "near end average distance" and "far end average distance" is a
measure of the misalignment of the spindle axis with the ways.
RDM tells us to put a shim under the near-side foot at the head stock end of the lathe. What do I need to do here? If I look at my mini-lathe drawing, are we talking about under that head stock casting #10, or under the ways casting #32 on the left side, or under the rubber donut #127?
A little confused, help me get un-befuddled. Thanks!
