- May 27, 2016
- 3,480
Yes - that was the possibility I mentioned in post #34. I called it the "charitable" view. I think the odds are that Ryobi did not fit a bottom collector, but you never know. There may be a way to deduce this. Perhaps if @Suzuki4evr let us know what happens when he opens the tap, with maybe only a little pressure remaining. If Michael has never ever seen much water come out, ever, he can reasonably think that this arrangement does not work.Perhaps I was unclear. I was discussing a somewhat sensible design, not a tap above water line. What if there was a small internal tube connecting from that tap point to the bottom, like a petrol pick up in a fuel tank? For all we know there's a "fuel sock" on the end of the pick up, which would tend to minimize the drain from clogging.
Maybe, if he propped the compressor over a bit, opened the tap, and got sprayed with stale smelly old water, he would know.
[ DON'T DO THIS AT FULL PRESSURE !! ]. Nearly all air released will do.
