- Apr 14, 2014
- 3,189
The Cincinnati is sounding better all the time. The work envelope is similar to my Sheldon although the total length of the machine you're looking at is a bit longer. I would certainly consider it if you have the space for it.well I went back to the machine tool dealer and the 40” Harrison is pretty beat. There’s definite wear in the ways and the thread dial is missing, brake assembly is making noise on the drive sheave end, I’m gonna pass on that one. The 25” machine still is under consideration.
I heard back from the guy selling the 15” tray top Cincinnati and it’s a 15X42 and the total length is 8 feet. It’s a couple hour drive to go look at it but I’m thinking of borrowing a trailer and taking a ride. What should I be looking at on the Cincinnati beyond the regular items? Any Cincinnati specific faults or weaknesses that I should be on the look out for?
As for a trailer I would recommend a drop bed style. I've used them to move several machines. The bed is hydraulically lowered to the ground for loading, then raised to the normal travel position. It makes loading and unloading much easier, and minimizes the chance of tipping the machine while loading and unloading.
Here's a link to some available from SunBelt Rentals.
Platform Lift Trailer Rentals | Sunbelt Rentals
I rented one identical to the first one on the list. It had a 9' bed and load capacity of 10,000 lbs.
I didn't rent the one I used from them. I found the same style available from a local rental company. It cost less than $200.00 for almost a week.
Here are a couple pictures of the lathe on the trailer. I didn't tow it with the Jeep, I used the Expedition. I just used the Jeept to turn the trailer into the garage.
