- Jul 10, 2013
- 1,190
I one time ran into a problem similar to yours. The problem is that with the small diameter drill bit and a small runout on your drill press that bit will bend. Make jig with two holes, one that fits over that pin or what ever that is. The other hole for the bit to run through. And you may have to clamp it. If you got a xy table, use it , better yet a mill or mini mill. I can't guarantee that this will work, but maybe it is worth a try. Good luck. Mark
