- Nov 14, 2016
- 3,010
I have a lathe with a 1-1/2hp motor which can be wired as 115v 17 amps, or 230v 8.5 amps. It came wired for 115v.
I'm going to get some 230v outlets installed, and just wondering if there is any reason why I would want to add an outlet for the lathe and rewire it for 230v.
Understand many advocate for 3 phase which has some advantages, but not sure what benefit there would be to single phase 230v power. I know less amps, but does that justify the expense of a new outlet and the work involved in re-wiring the motor when it is serviceable on a standard 115v 20 amp circuit?
