- Mar 26, 2018
- 8,411
Hello fellow Clausing fans,
My Clausing Colchester 15, came to me in very good shape. It's a 1970 English made lathe.
Two things bothered me though. The cross slide had 180 degree free play in the handle and the saddle/cross slide manual plunger pump was not working.
I got the operators manual and parts list for it.
The cross slide nut adjustment said to, loosen the back nut, tighten the wedge in small increments, tighten up the back nut and try it out.
I started out by this method and was not making any progress. As I moved the cross slide handle in and out it was binding, I noticed the adjustment or hold down cap screw would move in and out. I backed the wedge out quite a bit, drew the back not to the front nut by bringing the cross slide toward me, then I tightened the wedge until I felt the slightest resistance, then I tightened the back cap screw.
Wow, I have .009" in play and the operation is smooth as glass.
I think it must have been out of adjustment and I had no reference to begin with.
If you have the double nut wedge type adjustment on your Clausing, this method worked for me.
The plunger for the manual oil pump for the cross slide did not work. I took it apart, replaced the o-ring and tried it again, nothing.
The oil in the apron was changed before I started working on it. There is a plug on the side of the cross slide, I took it out, pushed the plunger a couple times and suddenly I had a volume of clean oil coming out. Put the plug back in, works great.
The clutch seems to be adjusted ok, It takes 4-5 seconds to come up to 2,000 rpm with an 8" 3 jaw chuck. The manual says this is normal. Good, I did not want to adjust the clutch.
Great Lathe!
I love it
Great Lathe!
I love it
