- Apr 14, 2014
- 3,173
I noticed in the background you have appears to be a Delta 40-440 scroll saw. Are you aware that model could also double as a die filer? I was looking for a die filer several years ago. I wasn't having any luck, so I toyed with the idea of converting a scroll saw into one. I was a bit surprised when I found a 1942 Delta catalog on the Vintage Machinery site that mentioned you could buy a chuck to accommodate files.The power feed is a nice feature, but not super user friendly. You need to hold the manual feed down close to the work, then pull the D handle down then bring the trip mechanism up to lock it, three hands would be nice. BUT impressive to see two heavy curls coming off an inch plus bit.
Like the longer feed handle on yours. Mine is inside the longitudinal feed handle and too short. The power feed controls look identical.
Greg
I happened across several model 40-440's at an equipment dealer. One of them had the file chuck included. I purchased it and found some files on eBay. I've only used it as a die filer a few times, but it seems to do the job.
