- Jul 4, 2014
- 156
Group, I bought a tachometer with hall effect pickup and I want to add it to my G4000 lathe. I am very much OK with the electronics part but I need some suggestions on the mechanical side. I am not sure what is the best/convenient way to fit the sensor. Where should I fit it? Inside the HS housing? At the rear end of the spindle? How should I fit the permanent magnet? I do not want to make holes anywhere(if I can manage or unless there is no other way.
I would appreciate if someone can point me pictures of similar projects so that I can learn from there.
Thank you
Prasad
Wynnewood PA
Thank you
Prasad
Wynnewood PA
