- Nov 26, 2017
- 1,517
I'm confused here. My understanding is that Acme screws are designed to transmit motion, and so they develop less friction than V threads. This makes them less useful for clamping. Also, I've read that an Acme screw and nut should be dissimilar materials to minimize wear--steel screw and bronze nut is common.
I turned this left hand Acme screw to replace the worn cross feed screw on a surface grinder. I bought a pair of bronze Acme nuts and turned external threads on them to assemble a double nut with more bearing area and a slight tension between the nuts to minimize backlash.
Turning Acme threads develops much higher lateral force. If you are turning a left hand Acme screw between centers, tighten the tailstock extra tight. A single point tool for turning small diameter inside Acme threads is the hardest lathe tool to grind for my money.
Correct, ACME is for motion and do not have the holding properties that a 60 degree thread would.
