I got a Nichols mill a short while back and one of the issues I had with it was when they were in production they used hydraulic cylinders to move the bed. The one I got, a PO had converted the bed to hand screw. While the set up he did was tight it did not give the full length of travel to the bed and was rigged to what I would consider a weak spot.
As an experiment I bought some all thread and some standard nuts and routed it the way the factory would have. It worked great. It was smooth and reasonably tight (about .004 lash) and gave me full travel on the bed. I spent less than $8 for every thing.
Happy with the results I ordered some acme rod and some nuts. Once they came in I set it up the same way I did the all thread and frankly the Acme is crap. It is stiff, grabby and has over .019 backlash. I have tweaked it every way I can think of with out improving it. I up milled a piece last night and actually got some minor chatter on the bed for the first time ever. Tonight I switched back to the all thread and am happy again.
What are your thoughts on why it is so much worse with the Acme. I think these results are worse than you would see from worn out parts. I did buy it from a good source and while I did not spring for the precision stuff I spent a little over $50 for the rod and nuts. I would think that it should be at the very least as good as the off the shelf all thread. It makes no sense to me.
