- Nov 6, 2012
- 128
I completed my first project - a Hemingway Machinist’s Hammer. It turned out pretty well. The finish on the tapered steel handle had a few visible grooves that I didn’t fully sand/buff out and some are visible on the aluminum/bronze hammer faces too. Straight Z-axis cuts turn out well with the feed but manual facing cuts are a bit iffy, even when I keep DOC low. I have a manual carriage lock but there’s some likely some play in the cross slide/compound slide.
My biggest challenge was counterboring the 7/16” through hole in the hammer head with a 1/2” drill. The hammer head was clamped in my 4-jaw lathe chuck. I used a 1/2” end mill in my tail stock drill chuck to counterbore and I think the first flute to engage pulled it off-center on the convex hammer head surface. I’m not sure if I would have seen the same problem counterboring a flat surface.
How might I approach that next time for better counterbore precision?
BRET
BRET
