- Jun 12, 2014
- 4,819
The question would be if there is any benefit to having the VFD setup for both motor speeds, in this case probably not because it is a half speed motor and the Hp is 1.5Hp vs 3Hp at full speed. There is usually additional torque going from an 4P to an 8P. The lathe uses a multiple section rotary switch to change both the wiring for speed and direction, and if I recall this lathe uses a clutch drive system. At the end of the day, I recommended that he either go with an RPC or a Phase Perfect. Phase Perfect now has three low cost models at 3, 5 and 7.5Hp and they are priced competitively with the RPC. Price wise this is also competitive to a VFD install and in this case it may be a bit more complex to redo all the wiring/controls.
I did a lathe install with a dual speed Dahlander motor for a Chinese lathe, I configured my own rotary switch (something like 12 sections), which would switch the motor windings and the input on the VFD for the 2nd motor. It went through a center stop position. Was a lot of work and the motor never performed well. I scrapped everything, got a vector motor for the lathe, and it worked wonderfully. I have also tried other two speed motors and they often do not do well unless it is a constant Hp and then I just run it on the higher pole setting with over speeding the motor.
Two speed motor and replacement vector motor.
