- Sep 4, 2013
- 113
So I came up with an idea (not sure if it's original or not) about my round column RF40 mill. I'm having the age old problem of losing center when I lift/lower the head, and was searching for a simple solution. So my thought is, what if I make to clamp plates, say that clamp to the column, one on top, one on bottom, that extend out to the rear, with a 1" rod between them, then make a slide block or linear bearing that attaches to the back of the head where it clamps onto the column that slides on that bar? In theory it would keep center as the head moves up and down, as long as everything was precise and tight.
I rarely need to move the head side to side, so I doubt I'd ever need to take the thing off, but it wouldn't be that hard to if needed. Thoughts?
