- Jan 4, 2021
- 1,817
Chris (ClickSpring) makes a lot of tools so many of his videos go into good detail on hardening & tempering O-1 steel. This is a good example.
What a great video.Chris (ClickSpring) makes a lot of tools so many of his videos go into good detail on hardening & tempering O-1 steel. This is a good example.
- Broach off center=0.0500". There is a wobble.a frew things I can think of.
How much of an off center is your broach holder? There needs to be a wobble.
How hard is that material? Did you try it in Aluminum to make sure it is working before trying in steel?
For a fixed broach like that the material must be a certain length to center itself. Adjustable broaches, you center depending on the length of the broach itself.
that hole does not look big enough. It looks like even the flat sections are cutting more than desired.
that's correct it still must be on center.The offset......if I convert 0.0500 to metric,it is 1.27mm from center to the offset point. So in other words when I made the offset in the lathe, I dialled in the workpiece to zero and then offset it to 0.0500 (1.27mm) using my DRO radius fuction. Is that correct or must that 0.0500 actualy be dubbled?
