- Mar 26, 2018
- 8,408
I think the revised plans show a bit more movement there?I'm going to go out on a limb and say the plan for this is incorrect. I watched another video from the guy in NZ who used those plans. I was able to see clearly that the pins only allowed the tap to swing at the tip, they were too tight a placement so the reamer could not float off center and have the whole reamer stay centered, only the tip.
So in my view the plan should allow for room to travel on those pins, not just re-align the tip. The reamer or even a tap since it can be used for tapping, should float into alignment all the way, not just a tip swing on a radius.
I'm pretty sure that the OLD vintage ones I saw did not align only at the tip.
Anyone know the answer to this question?
