- Jun 12, 2014
- 4,811
Short answer, if you can afford a knee, then get it and you will not regret it. The PM935TV is a great mill, and still manageable weight and size wise. I had a benchtop mill similar in size to the 932 and out grew it in ~4 years. It was my first mill and I could do a lot with it, but ultimately I am much happier with a full size (9x42) knee mill with a factory VFD/motor. Lots of options/brands when you go to a full size mill, for not much more than the 935 (but a full size knee is a lot heavier). The only down side I can see is if you plan to convert/do CNC at some future point, then a smaller bench top mill is easier to convert over, but then there are other options. Most knee mills will top out at around 4200-5000 RPM, so a wide speed range. A number of 935 mill owners went with the 3 phase 935TS belt mill and added a VFD, but the 935TV single phase is plug and play. I also feel a knee mill probably holds it value better over time.Would I ever regret not having a bench mill (can't imagine I would)? I don't want to buy twice.
