- Sep 2, 2013
- 5,099
Have had two helpers to do the heavy lifting on the sheet rock while I cut and measure, so have made some pretty good headway in the last week or so. Got about half of the electrical run, 125 amp sub panel off the 200 amp main for the machines, phase converter, and welding equipment. Insulation/vapor barrier is done in the original half of the building, with the exception of the area around the main panel. Still have more wire to pull there. The place is a total mess, but slowly coming together. Cheers, Mike
