- Feb 28, 2019
- 502
So I searched and found this:
I observed the "extra" 40 tooth gear on the lead screw and thought, cool, that's to swap in for the 20 tooth stud gear if I want to cut really fast threads (4 TPI). Well not so much, the stud gear appears to be two gears machined out of the same hunk of metal although the books says it comes off (with an arbor press?) not really clear and probably not ment for quick swap out to the 40 tooth gear.
So what's with the 56 Tooth (installed) and the spare 40 tooth gear on my lead screw? I could swap them and threads would be 1.4 times "faster"
What's the 40 tooth gear for?
Thanks.
Gear train is 20/80/56 with 40 tooth on the outside of the lead screw end.
Thanks.
