- Dec 25, 2011
- 10,525
Richard,
First, I'm a little more familiar with the 8530 than I thought earlier. I had it temporarily confused with the horizontal mill. I don't have a manual on the 8530 but do have the 8520/8525 manual. And my understanding is that the area that we are concerned with is the same on the 8520 and the 8530 Just today, in fact, I noticed that on the last page showing the cross feed (Y-axis) screw and nut, and the knee, there is nothing shown as holding the nut to the cross slide above. The screw that holds it, 696-018, is shown on the previous page.
None of this really makes any sense. If the error were due to variable pitch due to differential wear in the screw, it would repeat. If the error were due to failure to take up slack or backlash in the cross feed screw and nut after the first slot, all of the rest of the slots would show the same error, not progressively greater. The only three things I can think of that would cause a progressively shorter slot would be that the table was getting progressively farther away from the column as it moved from right to left, the part is not held down parallel to the X-feed motion (which would also mean that the slots wouldn't be perpendicular to the edge that the cut started from) or that the part is gradually moving on the table during or between each slot.
