- Aug 22, 2012
- 4,114
At last I can get back to scope work.
Now I have the 4 jaw chuck I can bore out the bearing shell.
There was just enough clearance between the end of the bracket and the lathe bed.
It was a hell of a job getting it centered, the slightest pressure on one jaw sent it way out of alignment
Both brackets bored and the bearings turned up in delrin.
The 3x8 mm holes are for the cross pieces that the clamp bolts will fit once the slots for them are milled out.
Then they have to be split in half. I think I will use the two angle iron guides again for that.
These were shaped with a file and small flap disk.
I cant make up my mind whether to bore a large hole in each side plate or not. No function just for looks.
