- Aug 22, 2012
- 4,115
Now working on the azimuth control.
I squared up a block of aluminium to hold a shaft with two bearings for an extension rod that links the flexible knob/shaft to the azimuth worm drive.
I was just going to drill through its length and counterbore for the bearings but the first drill bit snapped when it was almost through.
Hmm, no more ally to start again so I had a re think and re designed the block as shown in the drawing below in the hope a wood working solid carbide router bit would cut through the embedded drill bit and I could drive it out the remaining bits.
Heres the new design with the block and embedded drill bit.
Lets start milling and see
and finally, Yay! it worked
The angle milled to the face that has the bolt holes is so the shaft can angle out a bit for more clearance between it and the altitude control.
Have to counter bore the ends for the two bearings.
And of course more sanding and polishing.
