- Oct 16, 2014
- 314
Wasn't meant to be harsh. Wasn't even meant to be stern. Just trying to be matter-of-fact.That was a little harsh. Jake was a professional pilot for his entire career, as I was. Both of us have extensive experience and knowledge of how regulations work since we were involved in the MOST regulated industry on the planet, outside of nuclear.
After all, Jake was here for over 7 hours before mentioning he was a pilot - that might be a new record.
And you, and he, apparently don't really understand at all.
You see, being pilots, you participate in a well-regulated industry, yes. And that means everything is spelled out. Everything. The configuration of the plane. The rules of becoming a pilot - and staying a pilot. Every action, reaction, routine, emergency, and contingency is all spelled out, letter perfect. Maintenance, replacement parts, structural loading, maneuvers, speeds, and even which cubic foot of air you can fly in. As they say, the regs are written in blood. All published for the whole world to see if they take such a notion.
In fact, I don't see much virtue in such understanding when there's so little wiggle room.
OTOH, the ATF has a long and checkered past of arbitrary and capricious decision making. They routinely contradict themselves; countermand their own orders; and just pull stuff out of thin air without warning. How long could you fly an aircraft built under such conditions? Your regs keep you snug and secure in a predictable world. Your regs promote airman safety and preserve property. Seen any of that from the ATF?
When the FAA deviates even so much as a traffic pattern, a NOTAM is published. If there's questionable hardware, ADs are published. There's even a "comment period" for any discussion that might affect pilots, owners, operators, builders, or factories. You know how often the ATF does such things? Or anything like it? Or sticks with it when they do?
And what happens when you kill someone? Do you get promoted?
Comparing the mentality required to deal with the FAA as opposed to the ATF is apples and pinecones. Now I'm still not being harsh, but let's review. A guy with your instincts for rules should have noticed right off that there's no public certainty, which tells you what? There's no rules except what they say at any given time. Yet you failed to pick up on it. Now why would I be blamed for that?
There's an old bromide about this: you don't smack the bear. You don't wrestle the bear. You don't taunt the bear. You don't shout at the bear. You don't even get the bear's attention. Because even if you win, you end up smelling like bear. Anyone with alphabet agency experience knows precisely what that means.
Most people that get the attention of the ATF end up wishing they did not.
It's perfectly legal to build your own gun - been decided many times - so i tend to leave them out of it every chance I get.
