- Jan 28, 2022
- 839
Hi, I finished up a mod to an 8"horizontal rotary table that was on a mill I had bought some time ago. The table face was purpose modified for a specific job by the previous owner. There were cuts made into the surface of the table and the worm assembly was removed, so any settings were done manually, that said I still wanted to keep it as a back up to my 10" table but wanted it to also be a vertical unit also. I made an adaptor plate and mounted a chuck. Some of the work I do calls for nodding the head of my mill which then means tramming the head again. The set up I came up with allows me to angle the table by sliding the third leg back to the desired degree up to 45 without nodding the head. To return the table to horizontal I just have to remove the leg and it's brackets. Above all I now have a second table as back up. Thanks, Charlie
