- Dec 18, 2022
- 1,844
I am thinking about the stick on tire weights, if I use those I will place them on the inside of the chuck.I would not attach anything on the spindle to balance. If it gets loose, you could really hurt somebody. If you have to balance, grind material away.
If your chuck has a mounting plate, check if the chuck is mounted on center of this mounting plate and if the mounting plate is mounted on center with the lathe spindle.
