So... Do you guys use the stock (typically plastic?) bushings that come with the grinding wheels, or is it better to replace them with machined metal spacers?
I had a terrible time setting up my 6" grinder until I bought the Oneway balancing system. Now that cheap grinder with mid-grade wheels runs beautifully with minimal vibration. I love it, at least as much as one can love a cheap grinder. I am already wondering if this is the direction I will have to go. I guess the only thing to do is to mess with the setup first and see how it goes.
Final two questions:
If I choose to replace the wheels, would I be better served by the Norton 3x wheels, the Norton white wheels, or maybe something else altogether?
Finally, what grit(s) should I choose for sharpening metal lathe tools? This will (likely) be used for both metal lathe bits and my HSS wood turning tools. Will a really low grit (46?) be fine enough to put a decent edge on the metal tools, or will I need to 2-step it with a pair of wheels?
Thanks all, this forum has been a great deal of help for me as I get started in metal land. I try to do my research and answer these questions on my own, but sometimes I get overloaded with research and then can't make up my mind.
