- Apr 23, 2018
- 6,554
Fill the MC and let it sit, you might get enough "gravity bleed" to clear the bubbles overnight.
Had one roll off a jack stand once, ever since I have that nervous eye twitch every time I jack one up, my wife looks at me funny because I chock everything touching the ground, If the good lord wants me he'll need to hit me with a lightning bolt or pick the thing up with a tornado out of the blue and swat me with it....took a couple tries to correctly re-seat some flares and stop some leaks. Good thing about leaks is that they indicate fluid is reaching the back system.
Still not getting much out of the back drums with vacuum bleed.(shuttle valve immobilized) nor with gravity. With vacuum applied/released, I can hear a spring moving in the drum, so going to crack that open and replace the wheel cylinder since I already have the parts. I can confirm fluid movement to each corner while I'm at it.
I'll have to release the e-brake to do this, so I'll rely on chocks+tranny to keep her in the driveway, but with 3 corners on the ground this should be OK
I did that, and mangled the front-to-back line in the process, so those are both new.Replace the rear flex line?
