- Aug 26, 2013
- 1,061
Based on your description I would do the following.
1. change the design, and add some mounting holes to the top so it can be mounted to the face-plate.
2. toe clamp the part to your mill table.
3. rough mill the inside wall with the mill
4. mill the top to the correct thickness and mill all the mounting holes in it.
5. mount the part to face plate
6. bring the inner and outer faces to the proper dimensions as well bore your center mounting hole to dimension.
as a side note, you probably want to use cast aluminum plate, and not extruded round bar. Extruded bar has internal stress from the extrusion process that will cause warpage.
